programmable servo
Does ardupilot control how fast and how far a servo will move or do I need a programmable servo to do that?
    Ardupilot has slew rate limiting implemented for all of the servos. Just put degrees per second into your PID file.
  • Hi Donny, if you want slower movement of your servo (not faster), you can chop the total servo throw up in smaller steps. Every loop of the software will then move the servo a little bit until it reaches the desired position.
    Cheers
  • Thanks Chris!
    ArduPilot, like all consumer-grade autopilots, uses regular RC servos. They can control how far they move (degrees) but not how fast.
