Hi I want to buy this set 1x Brushlessmotor C 3536 1250 KV, 30A - max 40A can you check the detail and tell me what props do I need to use I have 30A ESC Kv (rpm/v) 1250Weight (g) 105Current (A) 30 - 40Model (g) 3D/Sport/SeglerPropeller. 9x4,5 10x4,7 9x5ca.900/1100/1700Max Voltage (V) 7,4 - 14,8Power(W) 530Shaft A (mm) 4,0Length B (mm) 36Diameter C (mm) 35Shaft Length (mm) 18Total Length E (mm) 54
It says the prop size in your post "Propeller. 9x4,5 10x4,7 9x5", The ESC is to small, if the max draw of your motor is 40A you need a 40A ESC with around 50A burst.
Are you putting this on a quad ??? Thats huge !!!
