Proper sequence to connect/disconnect Ardupilot
Hi all,
in order to load code into Ardupilot I have to perform the following steps:
- connect FTDI cable to computer
- connect FTDI cable to ardupilot
- power on ardupilot
- open arduino
Is there a "correct" sequence in which I should perform the above steps? Intuitively I would perform them in the following order:
1) connect FTDI cable to ardupilot
2) power on ardupilot
3) connect FTDI cable to computer
4) open arduino
Is this correct?
Also, is there a special order in these steps to turn disconnect Ardupilot from the computer and to turn it off? E.g., should I first disconnect the FTDI cable and then power down Ardupilot or the other way around?
Many thanks,
Michael
    There's no special sequence--any of those will work. The FTDI chip is in the cable, so your PC will recognize it even if the AP board isn't powered on.
