My PX4 was working fine up until an hour ago, but when I rebooted it I am getting a "no FMU input" issue, as the amber LED, on the IO side, is blinking at 4 Hz with the blue LED also blinking but at a slower rate than the amber LED. Hence, can anybody suggest any solution to this issue.
I greatly appreciate the time and consideration. Thanks in advance.
Hi, i received your message, and luckily i had no problems with the earthquake.
For my problem with pixhawk i contacted 3dr, and after some verifications they answered me:
"Following all the troubleshooting we have done, it seems your unit was damaged internally. I was checking your order status and unfortunately it is out of warranty so we can't replace the damaged unit you have."
So i bought a new one.
I hope you find a better solution.
Good luck!!
