  • Ok, I found the solution: SYS_Autostart: 4008, then it works
  • Hi, have you used the transmitter to tell the RX to sum its outputs? on the GR24 its SUMO 8 to sum all outputs on pin 8
    HTH
    • Hi Colin
      Thanks for your answer. Yes i set up the GR12s to SUMO16. The Sum output pin is 6.
