I just finished building my first quad using APM 2.6.
I did all the calibration process and when I planned to do the test flight and gave some throttle I noticed that motor #4 spins slower than the others.
I checked if it’s the motor or the ESC by replacing the APM output with other ESC and noticed that the same behavior happens on other set of ESC and motor.
Any ideas what can cause it?
Did you get an answer? I have the same problem.
The problem happened when I used 4S battery. I switched to 3S using the same prop size and the quad fly well
Hope it helps
No luck for me, I am already using a 3S. I have tried ESC Calibration (both multiple and single) and it still does not work correctly. I am working with the manufacturer of the ESC. Hopefully he will have an answer.
