Dear All,
I have used eCalc to calculate my quadcopter, but prior to going ahead with it I would like to hear your opinion. I would like to use the quadcopter to test my own control loops and I want the platform to be able to carry some weight (probably an SLR camera, additional batteries...).
Following are the parameters:
Number of Motors: 4
Weight: 2000g
Battery: Zippy Flightmax 8000mAh 4S1P 30C
ESC: 50A
Motors: Turnigy G10-810 (810kv / 375W / 42A / 140g)
Propeller: 13x45
Here are the eCalc results:
Battery Max. Load: 18.1C
Flight Time Hover: 19.55 min
Add. Payload: 2638g
Find attached the PDF printed complete simulation.
What do you think?
Saludos
Javio
Turnigy_G10-810_Simulation.pdf
  • Dear All,
    as already told by Gareth Rens, the G10 comes with a prop spinner of 8mm!!! Any ideas about to mount a 13x4.5 propeller with this motor? Somebody knows a 5/5 mm prop spinner (5mm motor shaft and 5mm prop spinner shaft) or any other solution?
    Thank you very much.
    Javio
  • Hey Javio, nice config, good efficiency. Try to lower the mAh for the battery and check if the flight time drops too much. A lower mAh will also be lighter. I'm flying a 1500gr quad with 3S 5000mAh with 2812 930kv motors and I'm getting about 10m hover.
  • Which ESC do you plan to use with the G10 on your quad ?
