I'm really mad with my quadcopter, I watched so many youtube instruction to solve my problem but I could not make my quad lift off without flip over.
My quadcopter is X configuration as following:
- Frame F450
- Props 1045
- 4 motors 2212, 1000kv, 13T
- 4 esc 30A
- Battery 3s, 5200mah, 30c
- Transmitter Devo 10, rx 1002
You guys can watch my video to know what exactly my problems are. I really want to surrender at all.
I made adjustment for props direction cw and ccw, motors spin direction and order, calibration for one by one esc, transmitter calibration, props balancing... BUt after all, It still flip over when lift off
https://www.youtube.com/watch?v=zG2NtdhugMM
Please help me out of this mess, tks you guys
Your video doesn't show a flip-over. (Have you actually taken off, flipped over, and crashed upside down?)
It just shows a little wobbling as you start to give enough throttle for the quad to move.
By itself, this doesn't tell us anything, and certainly doesn't mean the drone will actually flip over when you lift into the air.
Your flight controller could be very slightly off-level, and is trying to level itself, but can't, because it doesn't have any altitude to do so. (your homemade legs and feet don't look highly standardised!)
When the drone is so close to the ground (like, actually touching the ground), minor wobbles like this are common. Many people here have had them. In fact, the developers warned in the past that you must take off quickly and confidently, until you reach a few metres in altitude, so that the machine can take over and stabilise itself. But if you try to take off very, very, cautiously, and gently, and try to control every little wobble you see, you will flip over and crash.
If you try to fly a drone of that size in such tight indoor spaces, I'm afraid you probably will crash, even if the drone is perfectly fine. I certainly would. Find a big, safe, outdoor space, and try a full take-off - to 5 metres or so, and see what happens.
Yes, if you have made real mistakes in assembly, you may crash. Everyone crashes. But if you haven't, you will never find out, testing it like this (in the video).
It's scary, yes, but everyone has to get past it.
Please note - you are responsible for your decisions, and the results.
(And Loiter mode is a bad idea indoors - it depends on GPS lock, which is very unreliable indoors. And if the drone gets confused, the result might be sudden disaster, and injury).
Good luck.
George
(Oh, also - sometimes Mission Planner spontaneously re-sets the frame configuration from 'x' to '+' without tellling anyone. You have to re-check this from time to time. If it does, you will flip)
1
2
of 2 Next
