Posted by hunter scott on October 27, 2011 at 6:28am
In ya'lls experience, what is the maximum altitude that a standard sized quadrotor can reach? What is the limiting effect that keeps a quadrotor from getting any higher?
I am no expert on this, but I think there are several factors:
1) Laws - restricted ceilings 500ft in USA I think
2) Altitude sensor if there is one, is most likely scaled and therefore its accuracy would diminish as you get higher or lower than the scaling factor.
3) VFR - Pilots eyes, at 500 ft most quads are a dark dot in the sky making it dificult to navigate if you loose orientation
4) FPV - Signal range - I did tests that made it possible to fpv at a max range of 700 feet up and 3300 feet away using futaba 9c 2.4g and 5.8g Vtx in a suburb like setting.
