Need help.My quadro is drifting to the left.Both axis balanced. No visual vibration.Must use trim on the radio to keep it from drifting sideways.Level set 100%Tried reset, and clear apm.Noe succes so far.Any suggestions?
in flight leveling can help. (Arm your quad for 20 seconds to enable) Also make sure you're running 55
Jason
All quads will drift a little unless they're in GPS-controlled loiter mode. How much is yours drifting? (how much trim do you have to add?)
