helloi have read that ardupilot can flight-mode RTL / OFF / autonom.flightin manual i read thats possible to fly by wire only with unplugged GPS....- its possible to change the flight-mode in flight (with rc) to fly by wire with PLUGGED GPS also ???i will used ardu only for RTL & fly-by-wire (fpv)olli
Yes, it is possible. Just change the code. That's the advantage of open source--you can do it yourself. Check out the "stabliization" section in the Amain tab.
