Radio Calibration: Is this normal?
Hi People,
I was calibrating my radio and here are the found values (via Mission Planner):
3691040617?profile=original
I use Turnigy 9X CH9 Transmitter (Mode 2). Can someone tell me if the values are normal? Normal range is 1100 - 1900.
Is there some way to set up the Transmitter to give me the right values. I have started a discussion here, a couple of days ago but no one replied yet.
Can someone please help?
Thanks.
    You can adjust the End Points on most computer radios, normally they're set at 100% -100% but some can go to 150% -150%.
    The Trims and Sub-trims should also be at zero. Yours seem a bit out, I would reset the model to default and see if you get the same. Some transmitters have poor quality (or dirty) potentiometers and give those kinds of readings.
