well the story began when I updated to the newest frimware (2.66) when I had upgraded I could not connect to my APM 2.0, it would always stop on error showing this messageand than I get "connect failed" and if I click detail I get this
so I decided to downgrade back to 2.4 or 2.5 but then I ran into another problem that I did not have before, at the radio calibration tab it shows 0 (zero) on all channels like you see on the image belowdo you guys have any clue what is going on? my radio works (if I connect the receiver straight to the ESC I can run the motor) I also tried the CLI interface but with no luck, it also just shows 0 on all channels
