I have the 3dr telemetry kit, it was working perfect, and all of a sudden (i try to write in english) thay don't talk to each other anymore.The 2 green lights are still, but the air module is not reconized anymore. I plugged it with ftdi cable and try to talk with mission planner without success (can't identify radio) the software says. Then I tried with the 3dr software same result. I then tried to push the at command by bypassing 3rd all and the ground. I had a red light but can't talk with it to push a fresh firmware. I think a part of it is dead.Used it 3 days only. Do you have an idea? Is it possible to buy only the air part?
What else can I try?
Thank you.
  • I am having the same problem and have tried all of the same things to to fix it that you have.  I even replaced the air module because I thought it was bad, but still no luck.  Mine was working fine until I updated to 3.0.1, but that could be a coincidence. For now I suggest you don't buy any replacement hardware like I did.
