Radiolink Mini Pix does not save the configuration
Hi, I have a Radiolink Mini Pix, in which I installed the arduplane firmware from its official page "http://www.radiolink.com.cn/firmware/Plane/stable/", all good until the controller starts and It works, I make all the necessary adjustments, but when you restart the mini pix, it has not saved anything, it does not save the configuration that I did, what can I do?, I go to the section "Complete list of parameters" and select "Write parameters", but still it does not save anything, when disconnecting and reconnecting the mini pix, it is as if it had not configured anything.
Psdt1: try to load this other firmware from the official radiolink page "http://www.radiolink.com.cn/firmware/Plane/stable/del_mtd/", but the board does not work, the PC does not detect it and the status of the LED does not turn on, I had to reinstall the firmware from the previous link.
Psdt2: I tried stable firmware versions for minipix from the ardupilot page "https://firmware.ardupilot.org/Plane/stable-4.0.4/mini-pix/", but it seems that none works, the board does not work when loading this firmware
Psdt3: I also tested the version of the mission planner for radiolink, with no results.
I would greatly appreciate your answers.
  • Sorry for the poor translation, I live in Brazil so I don't speak English.
    try to re-release the rantron chip.
  • Hello I was having the same problem, searching I didn't find a solution until I saw your publication so I solved the problem myself, what I did was to resold the rantron chip so from that all the settings are saved, you can try another solution that I get like this answer from the radiolink team =
    Dear Sir
    Thank you for using Radiolink products.
    First, try to use the power module to power the MINIPIX, and then connect to the computer via USB. If the computer's USB power supply is insufficient, recording of the parameter fails. Check the MINIPIX version, as defined in the figure below, and select the correct firmware to flash.
DIY Robocars via Twitter
RT @a1k0n: Starting on a rough guess of the track centerline as an SVG. Then I use svgpathtools to generate equally-spaced points w/ direct…
22 hours ago
RT @a1k0n: This rules. My existing code isn't going to work *at all* -- the track planner and precomputed map are out. However, it forces m…
22 hours ago
RT @chr1sa: Our new @DIYRobocars track at @circuitlaunch is fiendishly hard & crashtastic fun. Combines hairpin curves with an intersection…
yesterday
The May @donkey_car newsletter is out, with news about release 4.2, next events and more https://donkeycar.substack.com/p/may-newsletter
yesterday
Friday
Friday
RT @breadcentric: Bingo card for AWS DeepRacer Finale, starting in 10 minutes on https://www.twitch.tv/aws ! #AWSDeepRacer #DeepRacer #Machin…
Friday
RT @NVIDIAEmbedded: It's #NanoFriday - the RB-0 uses the same suspension concept as #NASA's newer differential-bar rovers. This educational…
Friday
RT @chr1sa: On May 22, we're returning to in-person AI @DIYRobocar racing at @circuitlaunch. The Amazon @awscloud DeepRacer team will be pr…
Wednesday
RT @breadcentric: On my CV: Hobbies: Training bananas to race on tracks #AWSDeepRacer #DeepRacer https://t.co/MKe14hNyux
Wednesday
RT @breadcentric: See how the April AWS DeepRacer races have ended and a couple bits of news: https://blog.deepracing.io/2021/05/09/aws-deepracer-league-2021-update-11-end-of-april-special/ #AWSDeepRacer #Machin…
May 10
RT @sunilmallya: Representation Learning +Instance Transfer to learn new reward functions along with advantage based filtering of new exper…
May 9
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
