Random motor surges
== Edit 2/15 ==
I've replaced the 2.9 APM_RC libraries with the libs from 2.8, and commented out some code in radio.pde that referenced those libraries.  The issue's disappeared using this workaround so at least I can fly on 2.9 using PPM.
I'm running 2.9 on a Crius V1.1 board with HobbyKing 30A SimonK (bs_nfet.hex) firmware.  Motors are NTM 2826 1200kv motors with 8x4 carbon props.  Receiver is a TFR4-B running in PPM mode.
This is all on a tricopter with an AUW of 1180g.
As the video shows - there are random power surges in the front 2 motors.  For some reason the tail motor doesn't see these surges.  I've verified that both front motors and escs are working properly by hooking them up directly to the receiver, so solder connections are all solid.  I only see the power surges when it's hooked up to the flight controller (could there be a problem with the header pins?)
At the instruction of Aleksey - I played around with RC_SPEED which defaulted to 490hz.  I tried 400hz and 125hz.  Lowering the refresh rate to 125hz actually made the defect larger.  It surged harder and longer before it caught itself and settled down to the right speed.
At this point - the only thing I can think to do is swap out flight controllers - but that's going to take some time.  I thought I'd throw this out there to see if anyone's ever seen anything like this.
I'm attaching tlogs from both a flight and the most recent bench run. My board can't do raw sensor captures, so all I have is whatever standard telemetry gives me.  All I can tell from the logs is that channels 1 and 4 go high and low at random intervals.
2013-02-10 09-59-13.tlog
2013-02-12 16-46-17.tlog
  • Random surging of motors is sometimes a result of excessive vibrations (in alt-hold or loiter modes). (In flight, it results in uncontrolled, vertical flyaway).
    George
  • ok i switch receivers now it works
  • Going back a few years now from when this happened but the firmware developer had released a patch that fixed this problem.  I've since moved on to a different flight controller though.
  • did you ever fix this i have the problem with pixracer
    Lito P said:
    Not at all - they say misery loves company - and this one has me just about pulling my hair out.
    At the very least maybe someone else can benefit from whatever we find.
    Just a quick update - we're getting closer...my radio inputs are clean as far as the PWM logs show from the command line interface...so the culprit's somewhere between the input and the output...I think the APM2.5 has offloaded PPM encoding to the atmega 32u2, and I think this board's architecture is based on the APM 1.0 hardware so maybe the PPM encoder was on the main cpu?
    Digging through the code now to see if I can find any references to their version of the PPM encoder.
  • Excuse me, I try to understand what is happening.
    You try to run version 2.9 on a Cirius's board.
    But the difference is that Cirius use only I2C for its components, and APM2.5 use only I2C for adressing HMC5843.
    Release 2.9 use semaphore for SPI.
    If HMC5843 doesn't use the same semaphore you will have collision and some strange behavior.
  • Yep that's how I have my setup configured.  Internal FrSky f/s feature is enabled and set to midstick and output high on channel 5.
  • So, I couldn't let that go until I thoroughly checked out all the possibilities.
    I reflashed the board with 2.8 r3 and the issues are gone.
    I realize and fully concede that as a port, this isn't indicative of what you will see on APM, but I'm offering this up as another anecdote for strange issues I saw in 2.9.
    There's something on the PPM input side, not the encoding side, that's causing random low or high pulses to be recorded from the receiver.  I wouldn't go so far as to say this is connected to some of the reports of failsafe conditions being triggered but the logs show random pulses that would indicate the possibility.
    Attached is the tlog from the video above...
    Crius log is an export from a PUTTY session from a test earlier today when 2.9 was still loaded on the Tri.
    2013-02-14 20-03-50.tlog
    crius.log
  • Hey guys - just a quick update.
    At one point - you have to just bite the bullet and cut your losses.  I'm bypassing PPM for now for this board.
    I switched over to a PWM receiver and the issues are gone.  The issue lies in the PPM update loop falling out of sync with the PPM stream from the rX.  Whenever it would fall out of sync it sends a high or a low pulse, which explains the surges and cuts.  This was confirmed by grabbing the PWM inputs using the CLI logging capabilities.
    The high update speeds (RC_SPEED) set to 490 or 400hz actually helped to tame the pulses.  Setting it to 125hz gave the pulses enough time to reach their full potential hence the increase in severity of those pulses at lower update rates.
    This wasn't an issue in 2.8, so it was something introduced in the latest patch (for this port) but I'm going to let that dev cycle run its course, in the meantime - I have some flying I need to catch up on :)
    I would like to share one very useful troubleshooting tool I was introduced to.  I think you can do this from terminal in Mission Planner, but I used Putty connected in over a serial connection (FTDI).  I was able to run the PWM test from there and grab PWM inputs coming in from the RX and that's what was showing the high and low surges.
    Anyway - thanks for the assistance fellas.  I'll stay subscribed to this thread to see if anyone else runs into this issue.
    I've never even seen that board before.  To be honest, I wish all the people selling the clones would also contribute to providing support.  it's hard enough supporting the 3dr hardware let alone the clones :-(
  • Just swapped out the RXs with a known working one.  Same issue.
    It looks like that PPM encoder issue the dev team recently released an update for, but in my case - I don't have an easy way to update the Crius.
    I'll reach out to Aleksey and see what options I have (short of swapping back to pwm).  I'll start prepping up that Arduflyer in the meantime.
