Range of 3DR Link
What sort of range are people getting from the Stock Aerials on the 3DR Radios at 433 MHz?
I am currently running a clone board at each end but was only able to get around 50M range when flying yesterday even when I oriented the aerial at 90 degrees to the vehicle for maximum signal strength.
How best to increase the range?
Switch to genuine 3DR radio
Change the aerials
Software settings
  • If you're using ground module with integrated USB connector (plugged directly to PC) - do not expect nothing more...
    Check also stock antenna - sometime chineese clones are shipped with 2.4GHz antennas.
    You should have over 1.5km with simple DIY dipole antenna (that's what I have with my homemade SiK/HM-TRP modems).
