Rate Values Change using APM Planner Fail in 2.0.48
HI
When I tried to change the RATE_ROLL/PITCH/YAW values using APM Planner 1.0.86 or its older version 1.0.68, they refused to change. I tried several times then they got changed once. Then I tried again and this time every time there was write error display dialogue appeared on the computer screen. I switched to software version 2.0.46 of AC2 Now the Planner 1.0.86 easily changed the values.
Can someone help as it seems to be some code problem with 2.0.48
