Hello,
I am currently using Ublox PAM 7Q. But I am unable to get raw measuremnts from this module.when i try to enable RXM-Raw or SFRB msg its giving me 'NAK'. is there any other way from which i can get raw data or I can use this module with RTKNAVI?
Thank You in advance
Best Regards,
Sujay Kawle
Here is the only information I found on it.
u-blox7-V14_.pdf
When I tried to update the FW i got this message
Starting Flash Firmware Update
Loading and checking firmware image
Load FW binary 'C:\Users\ska\Desktop\FW100_EXT_G70.3069adf7509988c309850afa09da1458.bin'
Binary check success, G70 image valid.
Version: 1.00 (59843) Jun 27 2012 18:25:33
FLASH Base: 0x800000
FW Base: 0x800000
FW Start: 0x855DE9
FW End: 0x867D04
FW Size: 0x67D0C
Transfer Packetsize: 512
Transfer Packets: 831
Checking communication link...
Communication link OK.
Commanding Safeboot
Sending training sequence
Identifying receiver updater version at 9600 baud.
Firmware loader version 5.01 detected.
Suitable Multi-ROM image found
Check pass: u-blox7 Multi-ROM image -> u-blox7 ROM1.00-receiver
No valid FW header found in Flash: 0x359CA66C.
Identifying Flash
Flash Detection timed out.
Done in 11.9 sec.
Statistics:
Erases sent: 0
Writes sent: 0
Erase timeouts: 0
Write timeouts: 0
The data sheets say that RAW data is
Supported on:
u-blox 7 firmware version 1.00 (only available with raw data product variant)
The only thing I can suggest at this point is verify that your PAM7 is a raw data product variant with the seller.
I apologise I can't be more helpful at this stage.
What does this mean? Does it give raw data or not?
