RC_CHANNELS_OVERRIDE and flying with joystick
I'm trying to control an APM using Mavlink and a joystick.
I understand that the Mavlink message I need to send for this is RC_CHANNELS_OVERRIDE. Some of the fields in this message are obscure to me.
I notice that Mission Planner sets SystemID=255 and ComponentID=190 in the packet header, and in the body of the message itself sets target_system=220 and target_component=5.
Where do these numbers come from? Are they important? Are they constants? Do they change with APM configuration? Mavlink documentation says precious little about these.
Ari.
    Can you help me out with how you are actually encoding the packet and sending it over the serial stream? A tiny bit of example code would be very helpful :)
    I'm using Arduino BTW.
  • Have you made any progress with your project? I am trying something similar but I'm having a little trouble. I can arm and throttle my helicopter no problem. The problem is when I try to override more than one channel at a time. The copter seems to run at almost full speed only. have you experienced anything similar?
  • ComponentID=190 seems to match MAV_COMP_ID_MISSIONPLANNER member of the MAV_COMPONENT enumeration in XML.
    Ari.
  • My parsing code was inconsistent with MAVLink encoding. I was reading fields in the order that they appear in the XML, while in reality, MAVLink reorders them based on field width. So I was parsing the high and low bytes of chan1_raw into the target system and target component, and then parsing chan2_raw into chan1_raw and so forth. With this reordering, I get target_system=1 and target_component=1, which makes a lot more sense.
    Ari.
