I know that the APM manual states that for 6 mode selection you need either a 6 position switch or a 3 position and 2 position that can be mixed or for 3 mode selection you need a 3 position switch.
Does anyone have any suggestions on a good radio set, 3 mode selection is probably good enough for my needs however 6 would be nice to have. Would the futaba 6ex or spektrum dx6i be suitable or is there something more suited at the same price range.
I wasn't sure on the best forum to post this, here or the RC forum however I guessed someone in the APM forum may have specific knowledge.
Thanks in advance for any help,
Mark
On the DX7 I first entered system mode and selected a new model and made the input select page look like this...
[INPUT SELECT]
>AUX2:3P SW
AUX2 TRIM:INH
FLAP:INH
FLAP TRIM:ACT
Next I put the DX7 in function setup mode and made the travel adjust values for AUX2 +78% and -55%
Next I created the program 1 mix with the following values....
[PROG.MIX1]
>GEAR> AUX2 ON
RATE: - 33%
0%
SW:ON
OFFSET: 0
I have no idea if this is the correct way to do things or not however it gives me the following values for the corresponding switch positions on the AUX 2 Channel...
3PSW [2] GEARSW [0] 1160
3PSW [2] GEARSW [1] 1293
3PSW [1] GEARSW [0] 1376
3PSW [1] GEARSW [1] 1510
3PSW [N] GEARSW [0] 1684
3PSW [N] GEARSW [1] 1814
I believe these are all within the ranges required for each mode as specified in the APM code, I guess I could try and get them closer to the suggested values if I play around with it a bit more. Would be helpful if someone in the know could just confirm if this is the correct method or if I am doing something stupid.
Thanks,
Mark
G
I did find a config menu to assign switches but I could only assign to aux 2 problem is the receiver that came with the dx7 is a 6100 and only has an aux1.
Why do they have to make rc gear so counter intuitive?
I have a Futaba T6XA with the same problem - I only have two position toggle switches. Would I be able to program a mix of two switches to get four modes on the APM?
Neel
I picked up a DX7 today, just need to work out how to program it now... Looking at the manual that maybe complicated!!
Mark
Do you know if it is possible to do this with the futaba 6ex or would I have to modify the code to read the mode selection from two input channel (6 and 7) on the APM for the two (2 position) switch on the 6ex radio?
Thanks.
Patrick
