I am a new APM2 user. I just completed my setup and tried to power on. I am not getting power from APM to receiver, both when connected through USB or the battery. At first everything was working fine but all of a sudden the receiver was not getting power. I i connect the bind plug i see the blinking lights on the receiver, but after i bind the receiver with the the transmitter( I see a solid red light), when i remove the bind plug again im not able to get power on the receiver. I have attached a few pics please let mw know what i should do to fix this issue.
Thanks in advance.
Andy.
Hello Andy,
My receiver does not power through the USB either.
USB input is to Vcc not 5VDC. 5VDC is blocked with a diode from Vcc. See graphic below...
Test your receiver with the ESC output, *completely* removed from the APM to ensure the receiver is OK.
Your pictures look like the receiver is connected correctly to the APM (I use the last sets of pins).
I am surprised your receiver came on at all if only connected to APM.
If your receiver works with the ESC/BEC, it should be fine when the APM is powered with the ESC/battery connection. With JP1 in, you power the APM2.0 on the OUTPUT rail.
Nice photos, thank you!
-=Doug
I am getting 4.85v on the receiver pins.. but still I am not able to see the solid red light on the receiver and if i try to calibrate the radio none of the bars move.
