Receiver Wiring Setup
Could someone please tell me which wire goes where (from spektrum receiver to APM); specifically, which output from the receiver goes to the "pitch" input on the APM?  Normally with spektrum, pitch in Heli mode is output on Aux 1, so does Aux 1 from receiver go to pitch input on APM?  If so, then where does the "gear" receiver output go?
To summarize:
Spekturm Output                                      APM 2.5 Input
Throttle                                                     Input 8 (Thr)
Aileron                                                      Input 1 (Ail)
Elevator                                                    Input 2 (Ele)
Rudder                                                      Input 4 (Rud)
Gear                                                         ???
Aux 1                                                        ???
Aux 2                                                       Input 6 (Aux 2)
Aux 3                                                       Input 7  (Aux 3)
With my Aux 1 (Spektrum pitch) output plugged into Input 3 on the APM, I get no pitch movement on the servos.  Also, when I go into the Heli setup screen, I get an error message (see first attached pic) and my setup screen looks like this (see second attached pic).
  • Just an update; I go the folllowing wiring to work with mission planner:
    Gear                                                            Input 5 (Aux 1)
    Aux 1                                                           Input 3 (Pitch)
  • I think you are right and using the right info. At the time of the Wiki composition, there was no Spektrum information (I address this below).
    I am going to delete my first response -- don't want anyone to get confused (like me).
    That's amazing, I couldn't find the Trad Heli document you are using. Mea Culpa!
    There is no link off the path: Instructions --> Traditional Helicopters (but the Table of Contents takes you to the same place as the next line below)
    Rather, the path is: APMCopter --> Table of Contents -->(scroll down) Traditional Helicopters --> (pick your section)
    Thanks for pointing it out because I have a 450 Clone and want to employ APM on..and I will be using Spektrum also.
    I did read below the section you linked to..
    NB: We need info on channel settings for other radio systems!
    So even the Devs haven't used Spektrum. You are on the bleeding edge Jim!
    What TX /RX are you using? I know Robert L uses Futaba (go figure -- he is one of the Go-To guys for trad heli).
    -=Doug
