  • Thanks Paul Meier and all who have helped me with the information ..
    RFD 900+ now back to normal by using the tool outside the mission planner ..
    download firmware and clicking upload. completed. once again many thanks to all friends here.
  • 3702741898?profile=originalI've done everything for what you suggest and port (COM6) has been detected but the result remains the same .. is a solid red led light ..
    I was so confused with this problem ..
    • try and download RFD900ModemTools from their site
      • also can you connect the 2nd radio?
  • are the 2 radios same, same settings?
    Where you have any connection before?
    • 3702628247?profile=original
      and shows a solid red light..
      telemetry can not be updated or reset the default .. because it could not connect ..
      how the solution according to you? Thank you in advance
      • 100KM
        A solid read light means it is in boot mode ready for programming.   You might just have to load the latest firmware.
      • 100KM
        I checked an RFD900+ that was sitting on the bench here.
        Interface cable wire colors are in the same order as yours.     I get a solid green light followed by a blinking green light after plugging the interface cable into a USB port.
