ThanksPaulMeierandallwhohavehelpedmewiththe information.. RFD900+now back to normalby using thetooloutside themissionplanner.. downloadfirmwareandclickingupload.completed.onceagainmany thankstoallfriendshere.
I've done everythingforwhat yousuggestandport(COM6)has been detectedbut the resultremains the same.. is asolidredledlight.. Iwas soconfusedwiththis problem ..
Nana Sumarna > Paul MeierApril 17, 2016 at 10:50pm
I checked an RFD900+ that was sitting on the bench here.
Interface cable wire colors are in the same order as yours. I get a solid green light followed by a blinking green light after plugging the interface cable into a USB port.
Thanks Paul Meier and all who have helped me with the information ..
RFD 900+ now back to normal by using the tool outside the mission planner ..
download firmware and clicking upload. completed. once again many thanks to all friends here.
I was so confused with this problem ..
try and download RFD900ModemTools from their site
also can you connect the 2nd radio?
are the 2 radios same, same settings?
Where you have any connection before?
and shows a solid red light..
telemetry can not be updated or reset the default .. because it could not connect ..
how the solution according to you? Thank you in advance.
A solid read light means it is in boot mode ready for programming. You might just have to load the latest firmware.
1
2
of 2 Next
