Hi All,
I would like to introduce you to a new radio modem that we developed for very long range datalinks!
http://rfdesign.com.au/RFD900.php
Some of the key features of the RFD900 are as follows:
- Multi point and point to point link capability.
- Long range >40km depending on antennas and GCS setup.
- 2 x RP-SMA RF connectors, diversity switched.
- 1 Watt (+30dBm) transmit power.
- Transmit low pass filter.
- > 20dB Low noise amplifier.
- RX SAW filter.
- Passive front end band pass filter.
- Open source firmware / tools, field upgradeable, easy to configure.
- Small (30 x 57 x 13 mm), light weight (14.5g).
- Compatible with 3DR / Hope-RF radio modules.
- License free use in Australia, Canada, USA, NZ.
These modems are designed to support long range applications, while being easy to use and affordable.
These modems have been flying in various platforms and have demonstrated excellent performance in real applications.
RFD900 modems are now available at: http://store.rfdesign.com.au
Support within APM planner and the radio configurator from Michael Oborne is already available.
It works seamlessly with APM planner, all radio Mavlink parameters are available.
Update, December 2014: The RFD900+ with improved specifications is available now at:
http://store.rfdesign.com.au/rfd-900p-modem/
Seppo Saario
rfdesign.com.au
That was the solution, I can view the DP with photos now. Thanks again James!
I found those RFID RHCP antenna in the 900MHz band . Believing the specs, it's a 8dBi antenna, beam width: 72 degrees at -3dB.
After receiving the antennas, I took off the shell, which is a heavy metal tray with front pannel made of plexi glass. I laser cut a bottom and top plate out of plexi glass and use plastic stand off to mount them back together. As you can see I can save some space and weight as well. I hope to have some time next month to test those antenna.
On the right is the antenna taken out of the shell, on the left is the other antenna already in his new cover
Two antennas next to an IPhone 5 for scale purpose.
Another shot, this time the new antenna inside its previous metal tray.
Famous jDrones long-range telemetry sets have another upgrade, V2 and they are now available as 868Mhz and 900Mhz. All of them are using plus modems that are upgrade able for encryption and mesh protocols.
900 Plus set @ jDrones store
868 Plus set @ jDrones store
Set comes with all necessary cables, USB cable for ground unit, DF13 cables for both APM and Pixhawks, 2 x 3dbi Dipole antennas, 2 x monopole antennas for designated frequency.
And as always they all have strong cases and custom made adapter boards etc installed.
Both sets are PNP sets for APM and Pixhawk boards.
I am having good results using the 3dbi dipoles on my boat but space is not an issue. My GCS is using a tracker with a 8dbi patch and a 5dbi Omni. The RFD 900's are running version 1.9.
David R. Boulanger
Thanks David, I'll have a go at that.
The cat is outstanding!
Cheers,
Richard
Nice. I'd bet interested to know more about your boat. Do you run missions with it too?
Richard,
Yes it runs missions. See link below.
David R. Boulanger
http://diydrones.com/group/arduboat-user-group/forum/topics/arduboa...
Wow that's great thanks nice project!! I love the sound of the twins.
Ordered RFD868+ bundle and other parts from RFDesign . . . what a nice and easy experience.
Website was very easy to use and find what I needed.
Paid with PayPal, easy.
5hrs later received a pick up notice from FedEx, receipt, and shipping info was also on my email.
What great service, this was my first purchase from RFD, I would recommend them.
Thank you RFDesign.
Moxon Antenna:
I am researching antennas for my GCS and I came across moxon on antennas and this tool to give you the dimensions for a moxon antenna for the frequency you input.
For any one else that is new to all this and is looking to get a better understanding like I am, I thought I would pass on these tools I have found.
To fine tune your antenna the tool can generate a NEC model.
With that NEC model you can put it into the 4nec2 tool:
This tool is very cool, it allows you to play with your antenna to fine tune it. The tool gives you the ability to look at different aspects of your antenna.
This is far from my field so most of it is wasted on me but I find it very interesting.
If some one more informed could give us less informed readers their professional opinion of the moxon antenna?
I am looking at getting better performance than a 3dBi dipole antenna. I understand that this is a directional antenna, for that reason I wanted to use it on my GCS and was looking at putting it on a antenna tracker.
I have nothing against the rubber ducky I just want to learn a little and if I can build it then that's always more fun.
Here are the links:
Moxon gen: http://www.moxonantennaproject.com/links.htm
4nec2: http://www.qsl.net/4nec2/
Let me know your thoughts?
39
40
41
42
43
of 61 Next
