When using the Mission Planner to fly a task I monitor the HUD screen carefully.
I have just found out the RSSI reading on the HUD does not show the actual value of the RSSI when flying it only shows 99% or 0% when signal is lost. When I play back the TLOG of the task it then does show the actual value of the RSSI.
I had been relying on the HUD to be sure I was flying in full control all the time.
Can this safety item be corrected.
the hud shows packet loss, not rssi. hence why its a percentage and not a db number.
