RSSI feed from Dragonlink
Hi all...
I'm wondering if I can add dragonlink RSSI connection to the APM1, and have it report in the MAVlink stream to the minimOSD.
Not coming up with much in my searches.
JC
  • Hi guys, any progress on this?? Cheers
    Minh
    I can't think of an easy way to do this right now. What format does the dragonlink RSSI connection come in? Is it an analog voltage? If so then you could potentially add it via one of the analog ports on the APM, with a bit of code to insert the result into the RC_CHANNELS_RAW packet.
    That would require a few lines of code changes, but not a lot. Let me know if you want to explore doing this and I could give you some (untested!) code to try.
    Cheers, Tridge
