Rudder
My first post here! Hello, hello all...
I have the APM Beta downloaded now and uploaded to the APM-oilpan.
Everything seems to be working really well but RUDDER? I tested the IMU per instructions and sure it gives feedback for roll, pitch and yaw...
Is rudder not stabilized under stabilization flight mode? Ailerons and Elevator servos work great when I tilt, turn and roll the APM-oilpan but not the rudder servo.
Am I missing something?
P.s. I have read and read the manual!!!
    The Rudder is set to minimize the centripetal forces on the plane during a turn. If you're not flying it you won't see it.
    Jason
  • Ok!
    Please verify. Under Stabilization Mode:
    Aileron and Pitch are corrected. The servos counter act sudden movement.
    Rudder is not? If I turn the APM on desk the rudder does not correct for sudden YAW? Is this a feature or a fault in my system?
    I'm not concerned about mixing aileron to rudder.
    Rudder/aileron coordination is an option that's available. See the full Configuration Options. (It's called "Rudder Mix")
