Rudder Servo Direction
I am trying to confirm that I have the servo directions correct in stabilize mode.Aileron and elevator are easy enough - pitch the aircraft nose up and the elevator should move trailing edge down, roll the aircraft right wing down and the right aileron should move trailing edge down.Not so sure about rudder. I can see the rudder move as the aircraft is rolled - (presumably the turn coordinator?) If the aircraft is rolled right wing down should the rudder move trailing edge left or right? I think it should be trailing edge right but would like to make sure. Could someone please confirm (or correct me)?Thank you
