Log problem, SD card problem?
Problem with SD card or software?
I cant seem to get logs off my APM2.
Every time it starts, it says "ERASE LOGS". in the logs menu and on mission planner is says "no logs". It does this whether I have no SD card, the 3DR SD card or a working SD card (2GB) from a camera. Always, "erasing logs" on startup and "no logs" in the logs menu.
The SD card itself (the purple 32GB 3drobotics SD card) is not readable on a computer, it does not even register on the USB SD reader. Is that normal or do I have a defective SD card?
Not sure if this is a log problem (software), the APM2 SD card reader (hardware), my SD card(s), or my own stupidity.
Thanks for any help!
  • I´m running on 1.173
    What did you do in order to be able to read your logfiles?
    The card in the apm2 is not an sd card, it just looks like one... I think it is called a flash card or something? it runs a different type of file system so not compatible with SD..
