Setting landing speed lower then 30cm/s
I am working on a build using a HK retractable landing gear that is rubbish. It is giving me headaches from day one actually. It rattles and is flimsy. Therefore i would like to set the landing speed to 15cm/s. If i try this i get the message that this is below the 30cm/s minimum range. Is there a negative consequence or risk in trying to lower the value anyway? And more importantly, will this work in reducing the speed? ;)
  • I think you risk getting a false positive that you have landed.  In other words,  motors shut down and aircraft falls to ground.
    David R. Boulanger
    • Tnx for the reply David. In that case i will not risk it. ;)
