Setting servo limits
Its it possible to set servo limits through mission planner or do I have to edit it in the code somewhere?
I need to limit elevator and aileron travel down to +/- 15 degrees, in manual mode I've done so through the TX, but when I switch to stablize the APM exceeds those limits and causes binding on my servos.
    I've re-calibrated in mission planner with the servo limits set on my radio, and this has also limited servos in stablize mode.
    Thanks for the advice.
    As Doug says, you need to do a radio setup first. But you can also adjust them via the Mission Planner:
    3692254560?profile=original
    Did you go through the CLI radio calibration?
