HI guys,
Im trying to share the Ublox Lea6 gps with APM2.5 and Telefly osd.
The biggest problem I have is Telefly osd runs on NMEA protocol and APM2.5 uses UBEX ( I think ? )
I tryed playing around with Ucentre gps sowftware program and havnt had much luck.
Is there any one out there that is smart enough to make this work. Id even go to the extent of give the person a nice Donation for there time to work it out.
Use u-center and go to your configuration view. Set the UART1 Port output to "0+1" (1 = NMEA and 0 = UBX)
It works for TeleFly. I have recently upgraded to the Pro. It works fine but struggle to initiate. After a few reboots of the apm it work fine. Why is doing this?...I still don't know.
The MFD's GPS have only two NMEA messages and it works perfect when connected to the TeleFlyPro:
$GPRMC,.....
$GPGGA,.....
The HobbyKing LEA6 looks like this:
µb4È÷x¢èÝ=ûG¯•5βðí
™8ø»$gïµbÈ÷xÝâgó
f“9uÃñµyP9_go;!µb$È÷xn>Çÿÿÿxtp¼ øý«ÀÞ
$GPRMC,.....
$GPVTG,.....
$GPGGA,.....
$GPGSA,.....
$GPGSV,.....
$GPGSV,.....
$GPGSV,.....
$GPGSV,.....
$GPGSV,.....
$GPGLL,.....
UBlox from 3DR is only UBEX with no NMEA message.
Hope it helps
