Request for a shortcut key, hotkey or key combination for "Write Params" or "Save" in any tab that has that option available.
e.g., on a Win PC: pressing CTRL + S normally saves any open document.
So with the Mission Planner, while flying/testing, rather than having to use the track pad on a laptop to find the write* button after changing a parameter (*which is in a different place on every screen) one could just hit the familiar CTRL + S to write the changed parameters to APM.
This was requested and then implemented in Mission Planner v1.1.42 but removed in later versions.
Please could this be re-implemented?
Other useful hotkey's:
CTRL + D - disconnect from USB or Telemetry
CTRL + N - connect to USB or Telemetry
F5 - Refresh parameters
F2 - change to Flight Data tab
F3 - change to Flight Planner tab
F4 - change to Configuration tab
All these requests would make the Mission Planner much easier and faster to use!
Thank you
Michael, is there a shortcut for Write/Save Params? I can't seem to find it.
CTLR-N and D can be done using F12
ill have a look at the others
