  • Perhaps you should do the tutorials at arduino.cc to get a feel for the
    basic system then learn the extra capabilities and pinouts of the
    AP/APM boards.
    But here you go. The (second) simplest program to read data:
    int analogPin = 3; // input signal connected to analog pin 3
    int val = 0; // variable to store the value read
    void setup()
    Serial.begin(9600); // setup serial. This isn't required
                                            // unless you want to send the data
                                            // you read out the serial port
    void loop()
    val = analogRead(analogPin); // read the input pin
    Serial.println(val); // send debug value to the serial
                                             // port for a PC to process/display
