I'm wondering if it is possible to use SITL with X-Plane instead of the other sims in the tutorial. I'm awaiting my APM 2.5 and want to try out the APM on a UAV that I created in PlaneMaker. I'm decent with Linux and Windows so any advice that someone can give on performing this please do share! Thanks in advance.
Yep, you can do this! We're working on building a plane in PlaneMaker, moving it over the FlightGear and connecting the SITL to flightgear. We'll be releasing instructions, code and videos at the end of the year that will explain how to do this.
Also, you can rewrite runsim.py to connect to the XPlane UDP ports instead of the JSBSim ports, however I'm not sure what information XPlane's FDM provides. We're having a hard enough time just connecting to JSBsim through FlightGear (we're getting floating point errors in the Ardu.elf at the moment) so good luck!
