  • hello, did you have any success with the dead cat configuration params?
    Do they roll, tilt and yaw rates need to be tuned separately?
  • Have same frame and yaw problem.
    Frame SK450, lipo 2200 3s, Turnigy MultiStar 2213 935 kV, 10x4.5 props
    I build sk450 first. Good, stable flying. But with sk450 DeadCat conv.frame i have yaw issue.  Then i yaw left, copter drift left, yaw right - drift right. Don't know what is the problem.
  • I want to buildup this combination as well.  Will there be a problem configuring the APM2.5?
  • Probably useful if you indicate your battery cell count and motor/prop details as those will influence the settings used.
