0 SK450 Dead Cat - APM2.5 Posted by Richard Armstrong on August 8, 2013 at 11:13pm Has anyone come up with a successful set of APM parameters for an SK450 in a dead cat configuration?I'm using 3525-850kV motors, 11x4.5 props and 4.0 3s Battery. You need to be a member of diydrones to add comments! Join diydrones Tags: cat, dead, parameters, sk450 Email me when people reply – Follow
hello, did you have any success with the dead cat configuration params?
Do they roll, tilt and yaw rates need to be tuned separately?
Have same frame and yaw problem.
Frame SK450, lipo 2200 3s, Turnigy MultiStar 2213 935 kV, 10x4.5 props
I build sk450 first. Good, stable flying. But with sk450 DeadCat conv.frame i have yaw issue. Then i yaw left, copter drift left, yaw right - drift right. Don't know what is the problem.
I want to buildup this combination as well. Will there be a problem configuring the APM2.5?
Probably useful if you indicate your battery cell count and motor/prop details as those will influence the settings used.
