Skywalker Aileron and radio
So I am midway though building my first airplane and running into a few problems.
1. What is the best way to hook up/mount the Aileron servos? Is a y cable going to work for a ardupilot mega and if so what the best way to fashion one of these.
2. I have a eurglev3 (9x type mode 2) radio and i can not for the life of me figue out Aileron, the other surfaces wok fine, i have no mixing set up, I thought the mega had to use one channel for Ailerons. Andway when i move the right stick left and ight nothing happens i have to move it up and then left and right to get movement from channel 1. What do i need to do?
Any help would be much appreciated.
I plan on reflashing the radio wiht th9x when the pogo board is in stock but i would like to get this figured out.
Thanks!
I can attach photos and or vid if needed
  • I'm stuck at the same point and surprised that all the build logs I found were full of detail but then jump right over how to hook up the servos. I'm guessing they are set up using a Y cable but would like to see some pictures of the wiring.
  • Anyone got something i can try?  problem one was easly figured out but the radio is still being problomatic
