Skywalker users? - PID question
Has anyone tuned the basic PIDs from the default and found anything they can share?
I'm trying to figure out why the skywalker "example" config file has a P value of 3.0 for roll and pitch servo reactions where the default is 0.6. That seems a huge difference and no other example config is over 1.0.
I know it isn't a skyfun, but I think (with the right CoG) at least the elevator does not need a lot of throw.
  • Justin,
    Everyone's parameters will be a little different depending on how you've set up your plane.  Servo throws will be different from plane to plane.  What you need to do is go through the procedures described in the manual using the FBWA first.  check to see that you are getting your pitch angles with full up and down elevator deflections.  If not increase P.
    Here are my settings which have worked pretty well for me:
    3692318377?profile=original
