Slow telemetry --- Optimization of a common setup
Hi there guys.I have a setup which I imagine is quite common: Pixhawk running arducopter firmware; OrangeRx OpenLRS Rx (100mW) and Tx (1000mW) running standard OpenLRSng firmware, FTDI cable (3v3), Mission Planner on Win 8.1, 9xr flashed with OpenTx and modified appropriately.My problem relates to the speed of the Mavlink . I find that connecting Mission Planner via the telemetry link is taking ~10min and refresh of certain parameters is terribly slow.I have attempted the use of every baud rate combination with no success at increasing speeds. Flight testing with telemetry has not been attempted.Hopefully an expert can advise me further or answer these questions:Which serial settings have you found to be best? (Pixhawk telemetry baud, OpenLRSng data and serial baud, FTDI and Mission Planner baud rates).Is there better OpenLRS firmware out there? (E.g. Gitsly branch of OpenLRSng / UltimateLRS) ...... With Gitsly OpenLRSng I am unable to configure with Chrome Configurator ---- How does one use CLI to modify settings with the Gitsly branch?I have been trawling forums for days --- massive amounts of info out there but little that yields success. Please do help - I am certain this is a common problem.Thanks with much anticipation :)
  • Have you found a solution to the problem? I was using Ultimate LRS beta but it wasn't working that well for me.
