Soft Start Throttle
For me it seems APM system leaves about 20% of the first throttle travel as dead slack, then suddenly springs forth with about 20% duty cycle in the PWM signal.  This probably isn't an issue for most users, but for those of us with larger ships and/or supply rails, it tends to put a bit of stress on things.  Is there any setting anywhere to adjust this?
    This is the minimum throttle value. To edit this you must compile with Arduino. We can change this later to the Mission planner if needed.
    in your APM_config.h set this to the minimum value, 130 of 1000 is the default. (13%) Lower it but keep it high enough so that your motors won't stall.
    #define MINIMUM_THROTTLE 130
    Jason
    http://needed.in/
