Some Basic Mission Planner Questions
I have a few basic questions about setting different throttle positions in the mission planner. For example, if I am in straight and level flight I probably only need about 50% power. If I'm in a climb than I probably need 80 to 100 percent, and descending probably 0%. How are these set up in the mission planner? I see the list of general commands but I'm failing to see where I would adjust throttle settings for the different phases of my flight plan. Are there any good youtube videos taking you through the flight planning process? If anyone can help with these questions or point me in the right direction I would greatly appreciate it. Thanks
  • Dave, I'm a noobie to the APM 2 but I believe the autopilot will vary the throttle automatically to try and achieve the required altitude. Needless to say there is no way to simulate this.
    Check all the parameter menus as I recall a couple of throtttle limit options in there.
    There is a lot to learn with the APM2  but then it sure does a lot too.
  • Whats a guy gotta do to get a reply???
