something reversed or upside down
Hello, I have "+" setup. From the artificial Horizon of  ArduCopter configurator, pitch axial was fine, but left and right were the opposite. In prefly test, roll it to left, right motor power increased.
When I tilt up quadcopter, front moter power increased. I think that I got something reversed. How can I correct it? Thanks.
  • change connections of the left and right ESC
    (if you tilt it to the right the Artificial horizon should lean to the left!)
    Maybe you could upload a few pictures of your set-up as well. One showing the way the board is mounted, the other showing the wiring out the back of the APM board.
    Did you follow the instructions and place the board with the GPS connector facing forward?
