All,
I am planning on trying out different sonar solutions on my quad and was wondering how the transition between using the sonar and using the barometer for altitude hold is programmed? I am running ArduPiratesNG (rev. 527).
I have looked through the code and it appears it transitions at a fixed altitude, but I can't find where that altitude is set. I would really like the ability to change it, if possible.
Also, will ACM use sonar and baro together? Thanks for your help!
-Robert
At the moment the Sonar is used until circa 5.6 meters. After thtat Baro gets in.
To find the relative code follow this:
In system.pde you have:
max_distance is defined in the Rangefinder library (eg if you have MXBitx XL: AP_RangeFinder_MaxsonarXL.cpp) and for the XL EZ4 is 700 (in cm.).
If( AP_RangeFinder_down.distance > sonar_threshold ) {
sonar_status = SONAR_STATUS_BAD;
if (AP_mode == AP_ALTITUDE_HOLD || AP_mode == AP_ALT_GPS_HOLD)
Hope this helps.
Emile
Anyone have any ideas about this? Thanks!
**I am shamelessly bumping my own thread, since I can't see it on the regular forums anymore...I think it got pushed back to the second page, but isn't displaying.
