Sony Camera FPV
Greetings all,
I wrote an earlier post regarding Sony FX 100 iii gimbal support and was immediately helped.  It was brought to my attention (I'm a new guy) that any FPV kit that 3DR sells for either the Iris + or the X-8 + only spec for a GoPro.  Now that I understand gimbals, I was hoping to get an X-8 + for my Sony RX 100 iii.  I understand that I need to get a Hobbypower Gimbal but was under the impression that the FPV kit would work with my Sony RX100 iii.  I called 3Dr support and was told that I am wrong.  I guess I need to get some kind of FPV kit elsewhere.  I don't know that first thing about how to hook this up.
Any suggestions would be greatly appreciated!
  • You need to check what video output is available on it, in my quick google it looks like it has hdmi, if so you may possibly be able to use a suitable hdmi to a/v converter. Check the connector type.
    This can then be fed into to a analogue video transmitter. Avoid using 2.4Ghz video tx if you are using 2.4 for you radio gear.
