RT @gclue_akira: レースまであと3日。今回のコースは激ムズかも。あと一歩
#jetracer https://t.co/GKcEjImQ3t
RT @chr1sa: The next @DIYRobocars autonomous car race at @circuitlaunch will be on Sat, Dec 10.
Thrills, spills and a Brazilian BBQ. Fun…
I would say that due to the extra weight the power plant have to be stronger!
http://youtu.be/LtC2z9I-UC4
My plane is totally cover on fiberglass! a bit on the heavy side but I'm a happy camper wit it! Perhaps what I think that is the heaviest is the landing gear do!
http://youtu.be/VxXPKqYAIxQ
http://diydrones.com/group/x8 started a x8 group if you want to throw some ideas around
http://www.rcgroups.com/forums/showthread.php?t=1555543&page=72...
Kevlar? Wow. If I remember correctly, Kevlar does not respond well to the 'traditional' resins as used in fiberglass or CF.
'Lob' or lab project? How much time do you have for this build? If pressed and you cannot find a donor X8, buy a cheap one to use as the plug.
Warning - some foams are attacked by resins and such. This implies you cannot just take a new X8 and start layering up materials and resins to make a mold. Test an unused area first.
Search for 'fiberglass mold making'
Not knowing your experience with building (but I am encouraged at your interest and desire), this is the general idea I had regarding a monocoque X8...
CLICK HERE
I am envisioning wings made the same way that attach to a central body of the same construction.
You would lay in fiberglass or CF rods of your choice to give added rigidity (but I am not sure it would be needed).
All controls could be internal and access via hatches built into the part.
Depending on the size, a space frame is really over-kill where as a monocoque body with similar construction wings would be fine.
The trend to run to CF only runs the price up on the build. Using good quality glass cloth and resins eliminates the RF attenuation issues with CF.
I say find someone with busted up X8 and use it to make a plug for a fiberglass mold. You could then use the CF rod in critical areas, molded in to the monocoque. It is a time consuming construction method but actually makes a simpler model that you can reproduce.
This way you have total control over the internal mounting points, access hatches, etc.
I am considering such a method for quadrotor #4.
I am sketching out quadrotor #2 now.
