Spline waypoints missing from Mission Planner
Mission Planner just updated on my Windows 10 machine, and now I do not have Spline Waypoints available. If I select the radio button for Spline then create a waypoint, it makes a regular waypoint at coordinate 0,0. I have tried to do a fresh install, deleting everything, and it is the same. I see that this happens periodically, but I have never seen a response to anyone with this problem. What is causing this?
This is 1.3.36 build 1.1.5910.30936
  • So I hope you found a solution but are you trying to use Arducopter? If you connect to a Flight controller with arducopter you can get the spline waypoints to work. I think it defaults to Arduplane which does not have spline waypoints. Best of luck!
  • A new update, 1.3.37 build 1.1.5917.13431, happened today, and it now works for one more of my computers. The other still does not have spline, even after total uninstall, including files left behind, then reinstall. 3 Windows 10 machines:
    Old Laptop has worked right through all of this
    Teclast tablet was broken after previous update, 1.3.36 build 1.1.5910.30936, but works after latest update
    Desktop HP broken after previous update, still does not work.
