Starting a hexacopter
hi
i am planning to make a hexcopter and for that i would be needing the respected community help
I have shortlisted the following stuff
1. MOTORS
HobbyKing Donkey ST4010-820kv Brushless Motor
Specs:
RPM/v: 820kv
Dimensions: 51 x 23mm
Shaft: 6.0mm
Voltage: 11.1~14.8V
Weight: 194g
No-load current: 2.8a @ 11.1v
Max Current: 60A
Max Watts: 680W
Mounting Holes: 65mm
Prop Data:
12x8 - 11.1v - 39a - 1750g Thrust
11x5 - 14.8v - 44a - 2250g Thrust
10x5 - 14.8v - 30a - 1850g Thrust
2. ESC
HobbyKing 60A ESC 4A UBEC
Specs:
Constant Current: 60A
Burst Current: 80A
Battery: 2-4S Lipoly / 5-12s NiXX
SBEC: 5.5v / 4A
Motor Type: Sensorless Brushless
Size: 70 x 32 x 17mm
Battery Wire: 14AWG
Motor Wire: 14AWG
Weight: 61g
Programming Functions:
Battery Type: Lipo /NiXX
Brake: On / Off
Voltage Protection: Low / Mid / High
Protection mode: Reduce power / Cut off power
Timing: Auto / High / Low
Startup: Fast / Normal / Soft
PWM Frequency: 8k / 16k
Helicopter mode: Off / 5sec / 15sec (Start up delay)
3. Flight Controller APM 2.6
4. Battery 2-3s 6000mah
5. frame carbon fiber 650 mm
6. props 10x4.5 or higher if necessary
7. gps 7-8M
